Results 1 to 11 of 11
Thread: Conversion Oil Pan
    Jun 2009
    Petawawa
    Time Online: 3 Hrs 42 Mins 22 Secs
    Conversion Oil Pan
    I know you guys are pretty much all jeep on here other than a few of us running Domestics with some soon to be jeep running gear (front solid diff).
    But here is a V8 conversion oil pan that I am building. Now be the broke and cheap guy I am here is what I did.
    (You can buy a pan online for about $250 or a DIY kit for between $30 and $50)
    #1: Cut the flange off the gm 4.3 oil pan (red line on pic)
    #2: Cut section off pan so you have two pieces (red line on pic)
    #3: What it looks like seperated
    #4:Cut the flange off the gm 305/350 oil pan (red line on pic)
    #5:Weld in a piece of appropriate guage sheet metal bent to shape, piece should be like 4"(blue shaded area) and weld the flange from the 305 oil pan also (green shaded area)
    I ran out of welding wire but will have the actual finished product Pic in a couple of days.
    dsnt the 4.3 and small chev use the same oil pan sump?
    how come you couldnt use a small chev oil pan?
    Jun 2009
    Petawawa
    On a two wheel drive it is possible but on the 4x4 the diff gets in the way, and i am unfortunate enough to not be able to do the diff swap till spring.
    i see your working on a blazer s10
    ive done the swap but also did a solid axle swap at the same time
    Jun 2009
    Petawawa
    eventually I will buy a Jeep for a toy but for now the Blazer will suffice.
    sorry i was in the dark with what you were working on.
    if you need any info post it up i have done the swap many times
    are you gong to run the tbi?
    Jun 2009
    Petawawa
    I will later, long story short 4.3 died last week. The truck is a 91 and I have an 89' 305 that is tbi torn down and will start this winter on a build up, but in the mean time till I get it done I have a carb'd 1984 305 that is going in. It runs and will get me by for now. So when I do the axle swap I will put in the TBI motor.
    you can put the a tbi manifold on the 305carb engine
    it uses the stock 4.3 wiring just have to pull the eprom "chip" from a 305 or 350 truck and pop it in your 4.3 jimmy computer.
    its much easyer than yanking your gas tank and setting it up for carb
    ontario's west coast
    Avg. Time Online: 17 Mins 35 Secs
    i've been told that if you can find an AWD GMC Safari or Chevy Astro , you can use the oil pan from it. they are not as deep as the 2wd pan.
    Apr 2003
    Dornoch, ONT, CA
    Time Online: 3 Wks 14 Hrs 35 Mins 38 Secs
    Avg. Time Online: 1 Min 46 Secs
    ok but why wouldn't you just use pic#4 pan
