Thread: wtf
    Jul 2009
    wiarton ontario
    Time Online: 11 Hrs 43 Mins 39 Secs
    wtf
    hello i got a 87 yj six banger and it wont start we changed the starter, coil ,distributor, modulator, it runs but only if the key is cranked wtf am i missing fuel not the prob and lots of spark checked all the wires please advise
    Jul 2009
    wiarton ontario
    selkirk ont
    Time Online: 1 Yr 3 Mths 2 Wks 5 Days 3 Hrs 35 Mins 35 Secs
    Avg. Time Online: 38 Mins 59 Secs
    in the old days that would have been the ballast resistor. don't know if you have one of them.
    WHAT WOULD MACGYVER DO?
    Waterloo ont.
    Avg. Time Online: 18 Secs
    there are a couple things it couls be ie; fusable link in harness, ignition, possible grounds, .. try to put a jumper to the positive main wire at back of altinator this will backfeed the run part of ignition when the key goes from the start position to run position. if this works its a positive problem not a ground. once you know if its pos or gnd.you can chase from there if you find its a pos prob then test the ignition for power in the run position and test the fusible links under the hood.
    Sudbury Ontario
    87 yj has the motorcraft starter and ford style starter relay on the firewall,does it also have the other multifunction relay on the firewall ,about a foot below the ford one ? if so check there for a rotten wire or burned up fusable link .
    Jul 2009
    wiarton ontario
    no spark loses spark when key not cranking engine runs when the ignition is in the crank position only coils is hot
    Jul 2009
    wiarton ontario
    phuckn works now went hei if i could just get some heat
