Page 1 of 8 12345678 LastLast
Results 1 to 20 of 158
Thread: Project "What Cherokee?"
    So seeing as my build has completely changed directions from when I started my last build thread I fiquire I would make a new one, as for the name: Basically it's going to be only a Cherokee shell. Even most of the "Frame" is going to be plated or rebuilt.
    Here goes the plans and what is aready done and not changing:
    350ci SB mildly built on propane
    TH400 NP203/D300 Doubler
    Floor lift and belly tuck
    D60 Front 14bolt Rear
    Cage and Custom Dash
    Hydroboost brakes.
    I'm sure more will get added as the winter goes on and my mind has a chance to wander a little more!
    I hope to have it done by May 24 2010 might be hard, but better to stay optomistic!
    The day I parked it:
    Some shots of what i've got started.
    The Striping:
    The Motor:
    The Front Axle:
    Welding the 14 Bolt:
    north york.
    you got my attension.
    Dec 2006
    Hamilton(Waterdown)
    bustin out the tig!!!! wooooo ata boy! welding that sucker up with stainless filler??or just 70s-x
    Preheated using the oven to 450deg (dont tell the wife!!!), then used stainless filler. Now I need to fill it in with the mig. If you look on Pirate for the "Orb of Traction" you'll get the idea!!
    Dec 2006
    Hamilton(Waterdown)
    lol i got the idea for sure!!! wrap it up with a welding blanket after so it cools as slow as possible!!!
    looks fun buddy keep up with the pictures so i dont get bored this winter it will keep me inspired to work on mine haha
    I stuck it in a 5 gollan pale of sand to cool over 48hrs! Was still warm when it came out!
    Dec 2006
    Hamilton(Waterdown)
    beauty work man!! love it!
    Isn't all that wire more expensive than a spool?
    Not even close. Spool=resetting up the gears=new bearings=more cost.
    1 12lb spool of wire is only 60.00 and I will use WAY less then that and I used 4 TIG rods already.
    My bearings are in real good condition. So even though the rear is getting new gears, I can keep the bearings and only grab a 39.00 minor install kit. I know I could keep the bearings if I don't damage them while removing.
    And for the price of a Richmod spool I could almost get a detroit locker.
    Moving onward...
    Did some cutting and planning tonight.
    This will probably be the final position of the motor. I'll need to slightly clearance the firewall for the Dizzy. This position places the motor 2-3" higher the Advanced Adaptors Mounts, keeps the trans pan 2" higher the the lowest part on the frame, and my tight headers clear with 1.5" per side. I might need to cowl the hood a bit, but that does worry me one bit.
    milton
    Avg. Time Online: 39 Secs
    definately interested in this one. what worrys you about the hood cowl? if its the body work and whatnot lemme know. id have no problem doing the hood for you. for **** all. if ive got all winter to do it. just let me know.
    '99 superduty, 7.3L diesel. 4x4, ex cab short box. edge evolution programmer. straight pipe, torque converter lock up switch. single 7" stack, built tranny with some billet bits inside, 7' trac bars, pyro,boost an tranny guages. 4" lift in the front 5" rear. 305 70 16 mickey thompson baja mtz's on m/t classic 2's. now with dana 60 front, 10.5" rear 3:7.3's. 5" airlift bags in the rear.
    2002 polaris pro-x 440 with 2004 600 motor. walker evans remotes all the way around.
    No, cowling the hood DOESN'T worry me. I'll cut out whatever I need to fit!
    NICE!! Can't wait to see the final out come.
    http://www.youtube.com/staang
    Me too... I always wanted to drop a SBC into an XJ, and this is as close as I'll ever get.
    Dropping in a SBC is alot easier then this.
    Novak or AA make mounts, but this method is keeping the bottom of the trans pan 1 3/4" higher then the lowest part of the frame and the front of the motor block more then 10" away from the rad core.
    BTW Staang: whens the 5.0l going in? I had lines on one but gave it up because I had this SB already and Chevy parts are like 1cent candies at MACs.
    I have all the parts here to do it... Just getting some time with my fresh 2.5L... I'll prolly turbo the 4 banger before pulling it for the 5L
    Feb 2005
    Simcoe
    Time Online: 1 Mth 1 Wk 3 Days 15 Hrs 1 Min 52 Secs
    Avg. Time Online: 3 Mins 21 Secs
    what are those front axle from and what gears are you running?
    keeping an eye on your build. you want to build my HP D60? lol, prolly pm you for ideas.
    92 RENEGADE
    82 Toyota long bed
    Dec 2002
    the nuclear waste depository
    Time Online: 1 Wk 1 Day 13 Hrs 17 Mins 56 Secs
    Avg. Time Online: 42 Secs
    Whats the plan for suspension? keeping it simple with leafs out back?
    11 F150 tow rig/ DD
    87 Sami buggy
    99 XJ RIP
    91 XJ RIP
    86 CJ5 RIP
    Nov 2002
    Keswick
    Time Online: 6 Hrs 19 Mins 28 Secs
    looks good.
